Firefox is brokewn after updating to macOS 15
  • 3 replies
  • 15 have this problem
  • 1269 views
  • Last reply by n5k9kdntmw
Yesterday I have updated tp macOS 15. Sine then I have trupuble displaying any webpages in Firefox 130. Th econnection just times out. Any other browser such as Brave, Safari, Home, Edge are still working as before teh update. How to fix this please?
Reason was that all incoming connections for Firefox were blokec by the macOS Firewall. For some reason they coukld not be unblocked via the settings app either.
Solution wss to manually unblock Firefox using teh terminal like this: ```/usr/libexec/ApplicationFirewall/socketfilterfw --add /Applications/Firefox.app```
The solution was found here: https://old.reddit.com/r/mac/comments/1fif1gr/firefox_no_longer_works_after_upgrading_to_macos/
Sites? Post screenshots showing Firefox and other browsers. When I get to work I'll test so provide links. Did you try with Firefox in Troubleshoot Mode? https://support.mozilla.org/en-US/kb/diagnose-firefox-issues-using-troubleshoot-mode#search
Modified by jonzn4SUSE
Thank you very much for taking time to answer <3
